Pitool 273 updated from inside 272 version keeps crashing. Even after reinstalling 272 and upgrading to 273 gave the same issue.
I had to uninstall and reinstall 272 to get it working again. Has anyone else faced this problem? I’m on Windows 10 64bit
Hello,
Could you please contact with our tech support?
We may require the log files to diagnose the root cause.
Regards.
I am now on a working 272.
I will have to reinstall 273 again for that. Little worried it will not work on windows again. I had a similar problem a year back and had to make a fresh windows install to get it all work.
Meanwhile if it’ll help, my Nvidia driver was not updated for a month.
Hello,
Before you reinstall 273, please make sure the driver is up to date.
