Pitool 271 has under Settings General an item “Experience Home” to launch PE
a) Should i use the installer of PE 0.86 or Pitool 271 have already downloaded the latest Pitool ?
b) Where are saved the files of PE inside W10 ?
Thank you
Thank you
I think the Ptool version is 273. I would download the 272, and it will tell you to update to 273; from there, if you decide to use PE, it will also ask you if you want to download PE.
Hello,
You need to download the Pimax Experience from Pitool.
C:\Program Files\Pimax\PE
Thank you Pitool 271 downloaded PE 0.85 first time
To execute it i don’t have to run steam vr after pitool
However when i wear the HMD, I have an issue
I do not find PE in front of me in 3D space but for example very low or behind my position
and i cannot use it with Index controllers
Lucky with keyboard i managed advanced settings of steamvr for maxrecommendedresolution etc
but i would like to use it to execute games and for now i can’t
Is it an issue of 0.85 ?
have I to install again to solve this issue ?
Are there commands to move the position and save it ?
You probably already tried this, but a thumb-stick press using the index controllers will center the PE console in front of you.
No, i will try tomorrow
Thank you
