Please Post Pitool 259 Issues here. This Post is a Wiki use the pencil to add issues.
@PimaxUSA please edit a Close date for requested info for meeting.
[Center]
Issue/Bugs/Wishlist
[/center]
- Index Controller: Tracking improved but still needs more optimization.
- 5k+: Panel is Dim/Dark. Please Enable Panel backlight control.
- 5k+: ghosting in 144hz mode
- Fixed Foveate Rendering: Not working.
- Halved render resolution,: on purpose or is this a bug?
- Wish-list: Turn off chevron LEDs
- Wish-List: Optional setting to have headset remain off if pc reboots. (Like Bios remember last power state).
- Refresh rate: 64hz checkbox is missing (at least in 5k+ series 203)
- GPU Catalyst: some values create stutters only on right eye display (at least in 5k+ series 203). For some users, any value other than 0 create stutters/judder
- Performance: 10 to 20% less fps than 253 for same resolution
- Pitool Crash: Pitool crashes to desktop if started with the Headset connected and ON
- Controllers Unresponsive: On occasion, a steamVR app won’t respond to controller input until the SteamVR menu is opened and closed. (Could be SteamVR 1.11.13 related)
- Issue: ?
