Got my 5k+ today (yay) but I’m having some issues with PiTool.
As in the image, PiTool fails to render whenever the HMD is on. Amusingly, when the HMD is not on/connected it renders just fine. The windows popup on the toolbar seems to render correctly…
Does PiTool require some other package to function? Or am I doing something stupid?
It looks like you have something interfering. Maybe try uninstalling & install pitool 91. There is also a new beta featuring Some Brainwarp is smartsmoothing & refresh selection.
Addotional stuff installed from memory is visual redistribute & direct-X. Am curious though your taskmanager is showing steam bootstrap is running high.
@anon74848233 please add to earlybackers.
Think the bootstrap was just from steamhome rendering.
After a couple of hours of fiddling, what seems to have worked was restarting Windows multiple times. Which sounds idiotic, but something was catching i guess. Every time I restarted, more of PiTool would load until after the (4th? time) it finally started behaving.
So for antiquity, the solution is just keep restarting Windows until it works.
Now I get to worry about the more interesting stuff, optimizing and getting the unit to fit on my face properly ![:slight_smile: :slight_smile:](https://community.openmr.ai/images/emoji/apple/slight_smile.png?v=9)
