PiTool_1.0.1.90 installer file + Custom Location Instructions
Update: I found the original Pimax installer location hosted by Pimax if you prefer to download it from them: http://piplay-us.pimaxvr.com/PiToolSetup__90.exe
Old Info
Onedrive: PiTool_1.0.1.90
Link is back after uploading to my onedrive for 3 hours :stuck_out_tongue:
Hey Guys,
So I found the installer file for Pitool and thought I’d upload it as Pimax haven’t.
But I also have found a way with the help of another mate from r/pimax (Seishi) to install to custom locations despite pimax refusing to give us the option.
It might get a bit technical so please let me know if you need assistance.
  1. Download this template .reg file OneDrive: .Reg File
  2. Uninstall your currently installed PiTool.
  3. Edit the reg replacing everywhere it currently says: C:\\Program Files with your preferred location. i.e D:\\Programs.
    It should now look like this:
  4. Save and run the .reg file.
  5. Run PiTool .90 installer.
  6. Done!
Comment down below if you have issues =]
P.S the linked pitool installer I took from the temp download during its own update. You can do the same if you’d prefer not to download my version. It downloads to: C:\Users-–\AppData\Local\PiTool\pihelp.90.exe
Yes I saved the .90 temp also, just in case, I am surprised they didnt release it to direct DL.
Very good one to install a custom location :+1: as long it doesnt cause troubles :confused:
I don’t have a pimax to test. But this is exact same as installing to C. Only, it defaults to the ‘already existing’ location.
Download is broken btw
WUT. That’s really annoying. Took me like an hour.
Can someone assist to provide a better link? As my upload is terrible.
Fixed!
Thanks man. !
