Piservice.exe broken
I get sometime (often) when i try to start a game or when i try to change the pimax in direct mode or extended mode a message whose said: the piService.exe have a problem and you can click on debug or close the program.
Question: I hope a day the engineer found a correct driver but how can I restart all service and Pimax driver exe without restart all the time (often) my computer ?
Hi,
I don’t know if this will help but you can find PiServiceLauncher under the Services tab in Windows Task Manager.
Just right click and you should be able to start/stop/restart from there.
Hope this helps.
Cheers,
Luke
When the piservice fails the piservicelauncher is there to restart it.
But it will probably fail again.
I don’t know what make the piservice fail and when it happens i restart the computer.
