Hi Just wanted to Make it aware that i found a Bug to do with the Piplay Software it is only when the Piplay service is running.
Ok so i only noticed this problem around 2 months ago or so and i did not know what was the cause, at first i thought it was Windows 10, so i Google and Googled and tried every possible solution.
What happens is if i rotate the mouse in circles on my desktop the Cursor Freezes Every single Second, i count 1 second then freeze i start to count again freeze, so i noticed that when windows is on its loading screen before i sign in that the Mouse cursor does not Freeze, so i opened Task Manager and i started to disable background processes that were not being used and as soon as i stopped the Piplay Service the Mouse Cursor Freezing Stopped.
So i Started back up Piplay Desktop App Checked for any updates and its fully Up to date as of 15/03/2018, as soon as it started up Piplay Service my Mouse cursor started to Freeze Again.
So i reopened Task manager and Stopped the Piplay Service and again the Micro Mouse Freezing Stops, so i think that because my 4K VR Headset is not plugged into my Computer the Piplay service is Constantly Scanning my USB ports looking for the Headset and this is somehow causing my problem.
Here is a Video of the Problem so Support can see that it is Piplay service causing this
The Video is best watched on Youtube @ 1080p60 FPS “- YouTube”
As you can Clearly see in the Video my Mouse starts to Freeze up in 1 second intervals when the piplay service is Running as soon as i stop the Piplay Service the Mouse Freezing goes away.
Please note i have tried 3 Different mice reinstalled Windows 2 times and Reinstall Piplay 5 times and the results are the same it is 100% Piplay Service Causing this problem
