Hi, can you have both Pitool and PimaxCilent on the same computer but not run them at the same time? Or, do you need to uninstall Pitool first to run and use PimaxCilent?
Chris
Chris
They will uninstall each other, so the answer is no.
Maybe you can copy the files before they get removed and keep a copy of both, but WHY would you want to do that?
Does Pimax Client support the Vision series too, e.g. the 8KX? I should know, but last time I used my 8KX the Pimax Client didn‘t exist yet…
Yes I’ve use Client on both 8KX and Crystal.
