Update. Thereās an explanation:
https://community.openmr.ai/t/whats-going-on-with-pitool-and-pe/36925
I uploaded the file here
Cheers,
It looks like theres nothing actually newā¦ The emails were triggered by an update of the old threadsā¦
PiTool says its on the latest so will fire up PE later as it should do a version check.
Yes, I just saw that. Really shouldnāt let the pet monkey near the keyboard.
Jāai reƧu un mail avec apparemment les derniĆØres mise a jour , mais dans les chiffres des versions , on sāy perd , donc je vais suivre ce dernier mail , et je voulais aussi dire que je rĆ¢le tous les 3 ou 6 mois , car je laisse parfois tomber , mais je ne veux pas dĆ©nigrer le travail de @SweViver , car il a fait comme mĆŖme du bon boulot avec PVHOME. Faudrait seulement remettre en ordre les vĆ©ritables derniĆØres versions selon chaque modĆØle de casque sinon les nouveaux ne vont rien comprendre , personnellement je māen sort , mais je suis un backer des premiers temps. Trop dāinformations tue lāinformation !!!
Thank you because the email received on September 09, with the apparently more stable versions, leaves us a google drive link, with a text or the given link simply brings you to the first page of the OpenVR forum. Finally we are used to searching for ourselves;)
So the mail tells me that, but where is the zip, itās not in the attachments, not in a drive link or whatever, so iām okay with that, but if anyone has this mystery zip iām taker !!!
How to get started (IMPORTANT)
- Install the PiTool 1.0.1.264 (or later) here: Pitool 1.0.1.264 Beta
- Open PiTool, go to Settings ā General and DISABLE/UNCHECK āStart Pimax VR Homeā
- Go to C:\Program Files\Pimax\PVRHome\ and remove all content inside the folder (dont replace files, its more safe to remove the old files first)
*4. Copy all content from this ZIP/RAR and paste it into C:\Program Files\Pimax\PVRHome*
- In PiTool, go to Settings ā General and ENABLE/CHECK āStart Pimax VR Homeā to start the Pimax VR Experience
Pimax VR Experience should now start in the background and inside your Pimax VR headset.
Thank you for the MEGA download link of Pimax Experience 0.86
Hey. Turning IPD mechanical wheel it does its job, but doesnāt display in numbers. So I donāt know its 64 or 65. I didnāt notice if it happened after replacing default pimax logo or later, or maybe even earlier. Maybe some of you had this problem? Maybe I should reinstall drivers or something?
Iirc you have deleted the image for āeyesā in the pimax folder. Not at home so I cant check. Reinstalling Pitool and restarting the service resolves this for you.
thx for mega downloadlink
