Hello there, Can anyone please share STL file links that work without any hassle with the 8K X headset for HTC Deluxe Audio Strap, I found this link below Pimax + Vive DAS Adapter by Drcube - Thingiverse
But some people said the top part is too small for the 8kx. the 8kX is wider. might have to remix so I am a little confused about it whether to print it or not so please if anyone has a proper file that works 100% after print please do share. Also which material should I use to print, PLA, ABS, or PETG. I heard the user said PETG could be a better choice for this purpose so please let me know your thoughts on this. Thanks
The top hole I believe will not require the top adapter as the slot is wider.
Here is guide link on various htc vive das adapters.
https://community.openmr.ai/t/pimaxvr-mas-alternatives/34453?u=heliosurge
