Pimax Vision 8k plus and valve index controllers
Good evening
I am testing the Pimax Vision 8K Plus along with Valve Index controllers. It is not working.
See attached image - Device Pair button is greyed out. can’t be pressed.
When I launch Steam VR with pitool.exe / pi_overlay.exe / pi_server.exe all running in the background steam VR cannot see the valve index controllers or the base stations.
If I kill the processes for pitool.exe / pi_overlay.exe / pi_server.exe from task manager, then run Steam VR then the controllers can be seen just fine, I can pair them, update them etc. But the headset can no longer be used (of course).
How can i get the controllers running and the headset running at the same time ?!
Pi tool reports:
Current Version: V1.0.1.258
Headset Firmware: V2.1.255.260
Steam VR version 1.11.12
Windows 10
i7 8core
m2 ssd
Nvidia 2080 Super
That’s weird, your base stations are not detected either. They must come first.
Are you sure 9-axis isn’t selected in the settings page?
It seems like you did not turn on the lighthouse tracking mode.
