As said in title, I have no large 170 fov in pimax experience
I only got
90 potato
120 small
150 normal
But no large 170?
Idk what’s going on but I do hope next update gets that fixed? I hope?
I only got
90 potato
120 small
150 normal
But no large 170?
I think it’s got to do with the refresh rate You’ve chosen.
The full FOV is not available at the highest refresh rate.
He mentioned on Reddit this is also not showing for 90 and 120 modes.
OK. Weird…
Yea cuz I get only the options I mentioned above and I’d like to get the last option for fov, but hope it will be in next update fix?
I would contact support.
They might have a trick up their sleeve (or You’ve found a bug that they’re not aware of)…
You can also ask @vrgamerdude if he’s had the same issue as he has a 5K Super too:
https://community.openmr.ai/t/taking-a-test-flight-in-dcs-beta-2-7-yaw-vr-motion-simulator-pimax-5k-super-at-180hz-live-replay/35878
That’s the whole point I’m here, to report that there us no large fov option in pimax experience at all
Sorry but TBH I rarely use the Pimax Experience and just boot straight into steam VR for everything… old habits I guess… I should really take some time to try it out soon! []-(
But there will be a fix right?
Oh well. I guess I hope they can fix why I can’t see the large 170 fov option in pimax experience,
Sure they can… Maybe no-one tested with a 5K Super before and that’s why You’re the first to find the the bug…
Hello,
Thank you for reporting this issue. We will invite @SweViver and @arminelec into this thread.
So they could check this issue with the 5K Super.
Sincerely.
I did download the programs like normal, and so I wouldn’t know how this could happen?
I mean I really do want to see more then just “Normal 150 fov”
can you this not activate in pitool?
Hello,
We have spoke with Martin about this, the next PE update will fix this issue.
Sincerely.
Sweet, look forward to seeing the max fov I can
It doesn’t appear, no matter what I try in pimax experience and doesn’t work in pitool for odd reason
