Pimax is great if everything works but that is a big IF. It seems pretty unstable in fact.
Start SteamVR, only displays Starting in the SteamVR window, hangs and I have to end the task.
Switch my controllers on, oh I only have blue lights. Set the headset off and on, now my controllers switch on with green lights but the battery level is not displayed or only displayed on one controller.
Switch the headset on, now it doesn’t see my base stations, only rebooting the PC solved it.
Hey now I have a permanent red light on the headset and it won’t switch off, only disconnecting the current and re-connecting solved it.
These are all things that have happened in the last 2 days.
