Pimax prolem after firmware update
Hi
I just got a new Pimax. I installed as recommended.
Out of the box, it was not working. The software was searching for a Pimax, but didn’t find.
After a shutdown/startup cycle, Pimax started a firmware update. since them the led on top of the glasses are red-blue blinking, nothing is working anymore. It finds and recognizes the USB device and attempts to update again. But no further.
Thanks
Chris
I suggest you to set up the DFU driver and the Microsoft common runtime. After that, replug your hdmi and usb.
Auto update didn’t work for me. I downloaded dfu update utility and latest firmware. Hold all 3 buttons then plug USB, slowly release power, down and up. Used cmdline dfu upgrade and it worked.
Installa Pimax software poi steam vr installa anche softfware oculus rift in seguito virtual desktop poi avvia il tuo pimax 4k. Saluti
