does the front hinge out to allow access to the inside of lens
i ask because the top is open , and does not appear to have a cap, and even if it did dust will inevitably get inside and the occasional pet/ human hair and if the front does not hinge open it looks like it is going to be a nightmare to clean without a special tool.
Colonel Weng: Snake. Are you there, Snake?"
Snake: “Yes, colonel. I was just so intrigued by this customised HMD.”
Colonel Weng: “…ok… That’s nice, Snake… Anyway…”
Snake: “…It’s got a filed down chassis for better weight distribution, and a new battery system.”
Colonel Weng: “Fascinating, I am sure… As I was saying…”
Snake: “…It has a new strap that takes inspiration from larger devices, while the front is basically unchanged.”
Colonel Weng: “Snaaaaaaaake!”
Indeed need better details. If there still doing swappable lenses cleaning should be easy enough but yeah dust could still get in the area between lenses and screen and might want to clean.
The 2 holes are likely for the side tracking cams?
