Thanks. It was my faulty memory and not a typo by you. I typed 191 and changed it to 161.
EDIT: I literally typo’d the word typo. DOH
No worries were all heading towards old age.
Please help list the issue games, we will review it.
tks for your support.
tks for your detailed review, we will check the issue about Assetto Corsa.
Thanks for your interest!
I only play IL2 BoX and DCS flightsims.
In both I have those problems:
Sean @cfukpixie reports rendering issues in Prepar3d 4.3 i believe. (You might have noticed topic.
Why is reprojection kicking in when I have smart smoothing disabled? I liked it better when it would dip to 75fps instead of 45
For Il2 I ended up turning smart smoothing off.
Warping of image on bright scenes and then there is the render issue which degrades image quality very much that I would prefer to play with my mediocre frame rates than have smoother play.
Anyway I just have to wait for my eGPU housing to arrive and things should improve dramatically.
My opinion about new Pitool:
Did you get your headset working after all the instability?
No, its still working with rebooting.
Try installing steamvr v1.13 recently posted in the forum as recent steam changes are also affecting revive in terms of oculus games.
No, i’m not about Revive and about native support Oculus Games, it’s working good in past Pitool.
Native support of Oculus games is very strong advantage Pimax HMD for me.
I don’t think it’s native Oculus. Installing the early version of steam it was indicated that the Oculus games launched by pitool worked better.
I dont understand you. If you run oculus games in Pitool, then steamvr dont start. You can delete steamvr at all.
I was trying the beta with multiple games. In every one of them there was some stuttering, jerkiness, and the same time the fps was dropping below half fps. I was trying to find the cause for it and stumbled upon the following. When I set the cpu affinity for the pi_server process to the last physical cpu core and it’s logical pair, it completely eliminates the stuttering/jerkiness, and the fps stabilizes at the half fps.
I am not running oculus I am going by a post someone posted. So are you saying you don’t have steam installed?
Without steam installed can you run steamvr tracking? (Don’t have LHes yet)
Awesome which headset do you have?
Without running steam, yes, you can use the lighthouse tracking. The pitool uses them to emulate Oculus sensors, HMD, and controllers. But, as VTS was saying, it’s pretty much broken in the latest pitool
