My Pimax 4k stops working by itself. It just stays with the green led lit on the headset, is no longer red or blue like before, even with my computer turned off. I’ve tried reinstalling piplay, replug USB zillion times, restart computer… Nothing works. On Piplay, is showed that the USB and HDMI are plugged and connected, but still with a X in the illustration (attachment). I don’t know what to do anymore, I need help!
You shouldn’t be affected by the vega bug. It was working well with tge rx 580 4g?
If so try rolling back your amd driver to previous one. Your piplay looks to be a newer 3.x version. If it was working before try i think its 2.0.71 (one just before v3.x release)
Yeah, it was working well since january when I bought the headset. It was working normally until yesterday. Maybe it was the new version of Piplay, I was using the version 3.0.0.(something), so I updated to the 3.0.0.81. It’s the only thing I changed. Where I can download the previous version?
The last version of PiPlay (v3.0.0.81) was the bug,I tried the version 2.0.7 you sended to me, worked on the first try. Very thanks for the help, I was really worried
same problem here with the v3.0.0.81, but it may have been with the previous version too, i think i didnt get a chance to test it, before the 81 release.
ryzen 1700, vega64, win10
(running the vega firmware)
ill try to get an earlier verson of piplay and see if it fixes it too.
sadly no joy… with the 2.0.7 beta from above the PC locks up completely when i turn the pimax hmd on. needs a hard-reboot. if the hmd is turned on while booting, it locks up while loading the desktop, with the "welcome"text still half way through its fadeout.
updated graphicdrivers > makes no difference…
did any of the last updates fuck with(aka change) the firmware? first thing i noticed with 3.0.0.81 was that not even windows recogniced the hmd as a 2nd displaydevice(no “device connected/disconnected” messages)…
EDIT: just realized: i cant even refresh the firmware because now the whole pc locks up the second i power on the hmd… man, i realy hope my 8k isnt gonna be such a pain…
EDIT2: without connecting the HDMI cable i could refresh the firmware (btw. the downloadlink for the vega-firmware now wants a decryption key, which is pretty horrible for any new customer with vega) ( MEGA )
but it didnt change anything, guess i can try to roll back the graphics driver to an earlier version which makes no sense since i updated it only after pimax died on me. but hey what else am i gonna do on my weekend…
EDIT3: rolling back to catalyst 18.1.1 did it somehow… i am on piplay 3.0.0.71 atm and will not update anymore.
had to kill piserver and piservice in the taskmanager to get it connected and then switch to videomode and back to pimaxmode to get it to work. also the IPD adjustment just crashes if you try to adjust anything… so… still pretty far from plug´n´play…
