Hi, may I ask what’s version of Piplay & Firmware you used? Is that integrated graphics running in your PC?
Have you both inserted HDMI cable of Pimax and PC monitor cable to PC discrete graphics ports?
Are you using Steam? might want to try reinstalling that if thats where you are having issues.
I had loads of trouble with my Pimax as well. My main issue was with Steam not working with the Pimax and displaying VR content. I deleted and reinstalled Steam and solved the problem. I think my issue was due to previously using Trinus VR
I have exactly the same problem.
My card nvidia GTX1080
Just received Pimax 4K. Open box, connect everything.
Before installing Software:
1st Try: Monitor connected by HDMI, Pimax connected in Displayport through converter to HDMI. Not detectected as a monitor in windows 10.
2nd Try: Monitor connected by Displayport through converter. Pimax connected to HDMI. Not detected as a monitor in windows 10.
NO antivirus (apart from windows defender).
Install PiPlay 1.2.57 (intl).
During SW installation, appears 2nd monitor for 2 seconds. Then disappears. AFTER instalation, not detected.
I repet 1st and 2nd try again. Not detected.
Forgot to say I don’t have an integrated graphics card.
Besides, sometimes the ON/OFF switch does not want to shut it down.
I have been experimenting a bit more and sometimes, after a restart, I plug the Pimax and for a second, the second monitor appears in device manager, but then dissapears.
This seems a hardware problem, it is prior to installing any software, Just the headset is not reconized by the computer as a monitor. Maybe there is a faulty series as Jeronimo and me seem to have bought them around the same date.
Yeah it turns out the headphone jacks on my Pimax are broken and since they’re connected to the motherboard it stops it from working. I dont know why but that’s what pimax support told me. I have to get a replacement.
