@anon74848233 @PimaxVR @Sean.Huang
Should check this out. As for the ipd pot it might be possible to replace with a pot with more range.
Awesome find!
Alternatively surprised they didn’t use a pulse encoder instead of a pot.
Great work! Good to hear you didn’t break the hmd
Maybe add an external pot with a wider range to adjust the soft ipd.
For the brave hearted.
