I noticed today that in PE it is only showing the steam library located on C:\Program Files
I have at least 3 other library folders (one of which contains my VR games) and they are not showing up.
What’s the fix for this?
I also have a computer where only my steam library in C:\ shows up, but not Viveport or Oculus libraries which are installed in “non-standard” places.
Is there any way to suggest features to the developers? I think it would be very usefull, to be able to manually tell PE the location of different libraries.
