I think the 12k would be a huge sucsess if the company just goes with what worked about 8K-X and what works with the Crystal. Dont shoot for insane specs, just polish and perfect what you know.
I think a 12k that could hit the 8K-Xs “Normal” Fov setting, and have that FOV distortion free, while leverageing the extra resolution of the 12ks 6k panels for 35-49 PPD would be absolutely killer.
Set a balance of features that you have already demonstrated can be achieved, but do it better, with that added bit of polish.
49 PPD would put 12k at the same HD resolution and clarity as a ROKID or HMZ T1 has, but imagine that kind of clarity and image definitiom over 150 horizontal instead of 45 degrees, and without distortion.
The biggest issue that any of the players in wide FOV HMDs has had is in biting off mote thsn they could chew.
The OG KS 8K was Pimax biting off more than they could chrew.
8KX was a massive improvement.
12K should just be getting everythinh that was right with 8K X, plus everything right about Crystal.
