Hello,
Is there a solution to avoid having the default sound in the Crystal audio system ?
Every time I launch the Crystal, the sound switches to the Crystal audio. I have to select my Logitech audio system each time.
Thanks you.
Hello,
Thanks you.
Personally, I use SoundSwitch:
Thanks to you, but I’ve found a solution.
Uninstall Nvidia High Definition Audio. This is the driver used by the Crystal audio system.
Every time I start up the Crystal, the sound remains by default on my Logitech Z906.
