Can the Pimax be connected to the a VR Backpack like the HP Omex X or Z? If so, how to manage the AC connector?
As long as the backpack has tye right specs it should work. As for the hmd power plug if the backpack supports a 12v output should be good. Otherwise maybe a 12volt batter pack?
Thanks man, but my question is what is the connector?
its a 3.5mm x 1.35mm male barrel connector
I take something like this?
https://www.amazon.com/JacobsParts-3-5mm-1-35mm-Barrel-Connector/dp/B0744XJ249
thats 5V, the pimax is 12v, there’s a silverstone ECP-01 that works with a desktop PC, not sure if it would work with one of those you mentioned
OK, now i know what to do. yes,12 volts. I just picked a random image for the cable itself. My bad for explaining.
This thread is Solved
There was a fellow that made a sata or molex 2 12v adapter.
Just remember the pimax psu for 12v at 2amps.
If your getting the 8kX likely won’t need to worry as long as the 5v usb has sufficient power.
Cool to know, thanks for the advise!
I will be testing The Index, Oculus, Pimax and StarVR with the Backpack
Awesome look forward to hearing your evaluation.
