Is there any way to order a custom full stripe rgb oled 3860x2160 per eye hdm from pimax .
If money is no object a customer should be able to do that .
I know there are keycult commission custom Keyboards so it should be possible to order a custom pimax hmd with a custom panel , espeacially if money is no object .
I see you’re on XR, yeah I understand you. XR SDE is quite bad, much worse than on Vive Pro.
I also bought 5XR but was dissapointed by it & saturation. It would be a blast if we will have full stripe rgb oled 4k per eye Pimax, I would be happy even with default pentile stripe.
But seems they ditch OLED on purpuse & main factors are ppl complains about SDE & smearing.
Im shocked how much ppl here on the forum with those expensive Pimax HMDs & they don’t care about contrast, blacks & vibrant colours, my mind just can’t get it. How? It’s so much more pleasnt & immersve be in the world wich doesn’t look pale & where dark scenes are so natural & scaring.
I guess the only potentially good thing we have now is StarVR One which is dated by 2018 & can be ditched by Acer. But founders (devs of Pay Day) did the excellent work, I sad that they got problems & had to put this project on hold. With OpenVR compatibility for 4 cameras it should be very very good immersion experience & games compatibility.
I am in doubt if there are 5~6" 4K 16:9 RGB OLED panels available
I am sure BOE got oled displays with that size
Nope
202020202 202020
even if switching panels is the most easiest way to do it for Pimax HMD, there are always other ways how to imporove OLED resolution like:
- do some lightweight simple mechanic tha moves screens so you don’t need anymore to sacrifice panels resolution & lenses magnification parameters for IPD adjustment. I guess it will require to increase case size which is bad for many reasons though.
- do some filter similar to Samsung O+ but less blurry, to avoid black gaps & fill it with sibling pixels colour, less agressive than in O+ which can by some degree reduce SDE. Really Vive Pro resolution is awesome, it’s on par with 5k+ with all those pixels but with great colours & contrast, if sde would be less prominent much more people would be enjoy this wonderfull HMD
- partnership with panels manufacturers & ask to make it (I guess it has minimal chance as it would be too expensive if there won’t be enough demand)
- Do some other magic
