Hi, would like to try plast dip my Pimax 5k+ to give it bit more protection and better look.
Anyone used plast dip to pimax ?
I mean same as used to cars : Plasti Dip Your Car - The Complete Guide - YouTube
Layer would be quite thin so sensors would still work
Give it a try and let us know
I have written about that idea in another thread and i think it should be possible i also think that is basically the same method Pimax is using. Looking at this video Die Pimax RE Edition - Ein detaillierter Einblick - Wie gut ist die Qualität? - YouTube
it looks like it is just a PlastiDip coat on the new Units.
The only problem is see could be the IR sensors so it could cause a problem if the coating becomes to thick on the sensors.
One way to avoid problems would simply be to mask the sensors off.
Thanks , i gonna try. Its super easy to remove anyway
