When can we expect BW 2.0?
Yup I’ve noticed this as well. Getting about 70fps in Assetto and smoother and better looking than the Vive ever was!
Pimax will release BW 1.5 soon, 120hz on 5k+ .
Considering it will work only in small fov mode my educated guess is that Smart Boost will be in use here. Gpu will render game at 60fps, Smart Smoothing will fill every other frame. Panels will work async. Maybe will work smarter than limiting game to 60fps but insert only dropped frames, so we get variable refresh. Gpu and cpu will try hit 1440p@120 but every frame that is not ready in 1/120s will be faked aka Motion Smoothed. Exciting to see if this does reduce MTP. Nvidia research has something like 16000hz display, they for sure use ATW/ASW/SB to drive it
Unfortunately some Pimax Users need to use the same technique to get any 3D affect on their headsets .
you sure its not the FOV?
