i noticed if i start my Pimax 8K x (or any other pimax), the view is just fine without Parallel Projections on But when i use the zoom function, thats when it goes to a cross-eyed view.
Im forced to use PP if i want to use the zoom. Is this the only way around it?
But it’s not Pimax fault, the Devs aren’t calculating the viewports correctly.
It has been reported from what I remember, but they aren’t fixing their game.
All you can do is complain on the forums and write bug reports. There’s also a Pimax user called “blitze” who falsely repeated that it was fine. He has an 8KX now too.
If you use VREM offline, you will be able to use IL2 GB without PP with 3 in game level of zoom. You will have to set convergence setting for this three levels, that’s not automatic.
Their implementation of the viewports is amateurish. It’s all hardcoded, it’s clear:
Whenever a new headset arrived, they had to adjust the game for it. Remember the WMR headsets showing false world size? Or the Rift S? They could only “fix” the 5K+ when they had a unit in their office in Moscow? So their game doesn’t take the information from the API as it should.
It is hardcoded. They lack the skills to solve it. I bet the Reverb G2 won’t feel properly upon release as well. New lens design. Probably won’t be usable until adjusted by them as well.
you can try sharpen features. Even with the reverb, I’m using it.
The default mod sight should be ok.
And of course the capability to add your own images in kneepad like features.
Got it. Ye i came back to IL-2 after at least a year away and now the zoom changed settings and it works without the PP but crosseyed in some sections.
