This group consists of PimaxVR Staff Specialists for assisting PimaxVR Consumers with resolving Ticket.
Please follow this Procedure before Requesting help.
File a Support At
PimaxVR
You should receive a response within x Business days.
If you have not received a response after x Business days or Support personnel is having difficulty understanding your request. Please Direct Message(PM) this group requesting assistance.
Please provide the following Information:
Support Ticket # & Details of issue.
if your support issue is Tech related please explore:
Use Docs in Left menu to explore 2 & 3.
Pi-Guides & Troubleshooting. (#guides )
Community Support - review Solved and post question if needed. (#vrcentral:helpme )
I ended up letting Pimax update to 273, flashing the headset back to a Feb firmware, then letting Pitool autoupdate the fw. It’s back on the broken fw that flashes when selecting 90Hz. So the headset works at 75Hz but not 90. Not sure what changed as it was working before. NV drivers maybe?
The yellow light, let’s say it is “white”, is a feature of the latest firmware that I have also noticed, before when the 8KX was connected but in standby (without Pitool running) it was bright red. What happened to me with the yellow (white) led is that even if I turned Pitool on, it did not turn green in 90hz mode, all because of the cable, the poor quality of the cable and its degradation make it not support 90hz. It was to put the newly arrived fiber optic cable, everything solved.
