Hi all,
My 8KX was working fine, I then decided to follow the instruction at this link to improve visuals:
I ran the program that was specified:
EDIT: You might want to try running @BNP script:
How To Make Your Pimax Image/Picture/Screen Clear/Crisp (Increase Clarity)
Discussion
I have a program over here that will sets the steamvr.vrsettings in the correct file automatically maxRecommendedResolution = 16384; GPUSpeed’s = 2000; gpuSpeedRenderTargetScale = 1.5m; allowSupersampleFiltering = false; supersampleScale = 1; direct link: https://github.com/craftyinsomniac/WFOVFix/releases/download/v0.1/WFOVFix.exe
After running this and getting the following output:
Found the configuration file at C:\Program Files (x86)\Steam\config\steamVr.Vrsettings
The following values has been updated or added to the configuration file.
“GpuSpeed.GpuSpeed0” = 2000
“GpuSpeed.GpuSpeed1” = 2000
“GpuSpeed.GpuSpeed2” = 2000
“GpuSpeed.GpuSpeed3” = 2000
“GpuSpeed.GpuSpeed4” = 2000
“GpuSpeed.GpuSpeed5” = 2000
“GpuSpeed.GpuSpeed6” = 2000
“GpuSpeed.GpuSpeed7” = 2000
“GpuSpeed.GpuSpeed8” = 2000
“GpuSpeed.GpuSpeed9” = 2000
“GpuSpeed.gpuSpeedHorsepower” = 2000
“GpuSpeed.gpuSpeedRenderTargetScale” = 1.5
“steamvr.maxRecommendedResolution” = 16384
“steamvr.supersampleScale” = 1
“steamvr.allowSupersampleFiltering” = False
Would you like to save the changes? (y/n)
y
Done. Press any key to exit.
Now no matter what I do I cannot get the “Not Tracked” message to go away.
I have tried everything:
Re-Installed PiTools
Restarted HMD
Restarted Service
Re-booted PC many times
Powered of and on the Base Stations
Powered of and on the HMD.
I have opened a Support Ticket yesterday and I’m currently awaiting a response from Pimax.
Has anyone here experienced similar issues?, Can anyone here assist?
GPU Driver Version: 456.55
Pitool Version: V1.0.2.084
Firmware: V2.1.255.292
System Configuration:
CPU Specification Intel(R) Core™ i5-6600K CPU @ 3.50GHz
Mainboard Model Z170MX-Gaming 5
Memory:
Manufacturer (ID) G.Skill
Memory Type DDR4
Memory Size 32 GBytes
Specification DDR4-3200
XMP #1 16.0-18-18-38-56-n.a @ 1600 MHz (1.350 Volts)
Storage:
Drive 0
Type Fixed
Name WDC WDS100T2B0A-00SM50
Capacity 931.5 GB
Volume c:, 930.0 GBytes (56.0 percent available)
Drive 1
Type Fixed
Name ADATA SU800
Capacity 953.9 GB
Volume d:, 953.9 GBytes (3.1 percent available)
Graphics:
Display adapter 0
Name NVIDIA GeForce RTX 2080 Ti
Board Manufacturer NVIDIA Corporation
OS:
Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 18363)
