Hi.
I have a pimax 8kx kdmas 2075 that i bought years ago.
I recently had the amd 7900xtx but it dosent work with pimax 8kx kdmas 2075 headset.
Now i have a ASUS TUF Gaming OC GeForce RTX 4080 and like to report a bug.
The problem is if i select 90hz in the pimax software then i can see steam vr but every 0,5second the image dissapear for 0,1seconds so the screen is blinking for some wird reason. But i can move my head and there is no lag… If i start example dcs world then only one vr screen is turned on and screen is still doing the above.
If i switch to 75hz then i can use vr perfectly and have no problems.
I hope pimax can fix the software or work with nvidia to make the 90hz work.
Another issue.
( in flight simulator the cockpits feel so small and its near impossible to use the GPS screen in all planes due to the size. I think its a ms flight sim issue and not a pimax one, but it would be really great if pimax somehow could help fix it…
if i usei use openvr instead of steamvr then the cockpits are more real life size since we can adjust the size of the vr image. )
( small tip regaring the pimax 8kx kdmas… I tried 3 graphics cards… the radeon 6900xt work, the radeon 7900xtx does not, and the 4080rtx only work at 75hz or lower but have awesome performance )
