Hi everyone.
I have an 8K that is very likely out of warranty and needs repair. I cannot superimpose the Right and Left images any longer. I sent a message to PiMax ecommerce@pimaxvr.com but I received no answer.
A couple of things I need,:
Whom do I need to contact in USA?
What is the procedure to send it in, and how much may cost?
Thank you.
Can you post your Ticket Number?
Hi Helio and everyone.
I do not have a Ticket nr. I am trying to find my way around on how best to get started, it looks like many users are having difficulty going through what I think are the Email sign up channels.
Here is a link for submitting a ticket.
https://store.pimaxvr.com/helpdesk/order-support-1/submit
Welcome to the forum. You will need to create an account there.
Hi.
Thank you. I should be more to the point.
I am trying to find out if anyone, specifically, had that type of service, out of warranty, done and what / where is the repair being done, and how much?
If it’s going to cost over $200.00 and goes to China, or takes a long time, for repair I will likely just buy something else rather then go that route.
I am looking for a ballpark idea to see if it’s worth the effort.
I think nobody really has the beyond warranty service experience. I think it’s definitely possible, let’s wait what Pimaxquorra has to say.
Hello 8Kuser,
We are sorry on what had happen on your 8K. Could you please raise a ticket at Support. Our CS team will take care of your question,to check whether we can do the RMA with your 8K or other solutions for this.
Sincerely,
Quorra.Pimax
Thank you.
I found an answer from another source, not likely very accurate, but sufficient for me to make a decision and not pursue the repair at this stage.
Software fix? Just curious.
I would really consider making a ticket if it’s a hardware issue … can not hurt!!
