Hi All ,
My Pimax 8K Plus front LED is flashing continuously.
My parallel projection is off in Pi Tool
I get less FPS after last Pi Tool updating too , can you please help me?
Welcome to the OpenMR Forum!
Is the top power led purplish? If so it sounds like PP is sticking on.
If you haven’t yet. I would suggest filing a support ticket.
I know you were mentioning the front led. The power led goes purplish by the power button on top when PP is on as well.
Checking the top led might indicated the headset is stuck with pp on.
A reflash of firmware may also correct this issue.
Have you tried setting PP on and off again, the leds don’t reset in certain situations.
