Hi guys. Sorry for the stupid question. I have been away from the vr and gaming world for a while now.
I was wondering what is the distance of the wireless capability/signal that the pimax 60g can give us?
I have 2 acres of land. Proably half acre is flat and the hope is that maybe i can use the half acre land space with the pimax for playing wireless pcvr games.
Would that be even possible?
I am thinking with a quest 3 and native quest games maybe it is possible. But how about for pcvr games? Can pimax give us that?
So I guess we are stuck with no wireless pcvr gaming on a big lot.
I mean, we complain about pimax not releasing their products but in the end pimax is the only company on the vr market teying to push the boundaries of vr.
Otherwise someone should just tell us what is the alternative to pimax to get what pimax is working on and trying to achieve.
I have seen the trash that pimax received from the moment they appeared on the market.
I am sure the trash against pimax will never end but again, who has been developing what pimax has been developing since day 1? Anyone?
Pico just announced the the Pico Ultra with Wifi7 while Pimax don’t even have WiFi 6e enabled. Why is that trash talking Pimax?
HTC have had a wireless module out for years so I’m at a loss at to why anyone thinks Pimax are ahead in anything?
Even Somnium have overtaken Pimax in terms of optical quality.
Even Pimax have release videos now giving a reality check to some of their claims they made 2 years ago about the 12k.
We can all pretend in unicorns and fairies but what good does it do? I invested in the 5k+ Kickstarter in 2017 and still don’t own a wide FOV headset 7 years later.
I think that is the most honest and realistic video I’ve ever seen from Pimax and is exactly what was needed.
I like Jaap I think he’s one of the best Pimax employees they have now. He seems like a no BS kind of person and actually listens. He’s exactly what Pimax needs. Don’t over promise and under deliver.
Thanks for the info.
In there any of those headsets that have wide angle fov?
The issue here is havign a wide fov headset streaming vs small fov headset streaming.
Isn’t fov 1 of the major difference between pimax and those other headsets you mentioned?
I saw that video from pimax.
Nothing changed my mind about pimax.
I git into pimax because of them offering wide fov at a price that was somehow for the regular user since before there was probably 1 or 2 wide fov headset that were crazy expensive.
Did they deliver that?
Yes they did.
The building around wide fov requires big bandwidth hardware that i don’t think is there today since today’s tech might not be ready yet to be capable enough for good quality wide fov streaming. I don’t feel like i should blame pimax if it would need/take time for them to reach that goal.
Please let me know when someone else can achive wide fov, wireless streaming, at a proce that is ok because i don’t have 5k to spemd on a vr headset
I don’t understand how from.me askimg if pimax 1st or else , achieved what i asked (wireless pcvr gaming better if with wide fov), turned to be a discussion about pimax.
That is just Atmos. Maybe has some valid points. But his posts has nothing to do with what you asked.
I am not sure on what kind of range the 60ghz will give. The only thing for sure ATM is that you would need a pimax Crystal non light. As that is the only pimax hmd that is supported.
Because there is nothing to answer. The 60gig module only works with Crystal and probably wont go beyond 10 feet. It wont work with any furture Pimax headsets that are 12k or wide FOV as they will be tethered only due to bandwidth requirment.
So forget the wide FOV and the 60gig module unless you have a OG Crystal.
Your posts have nothing to do with his question. Except maybe your guess in range. As iirc 60g is not about range but bandwidth.
It is up in the Air. But so far iirc the 60g is intended to work with the Crystal Super. 12k? Probably not; likely will need an upgraded but only speculation whether yours or mine.
Kevin explained long ago now that the old wide FoV headsets would need to be upgraded to be able to use wireless. So essentially a new model
Pimax may yet release other wide FoV headsets using the reality platform. Only time will tell. A few YouTubers have demoed side loading aps on the Crystal.
While it is true pimax has several elephants in the room. Hijacking a topic like this is not really being a good community member. And has in the past had folks choose to leave this forum due to these kinds of shenanigans.
Pimax does not need help discouraging consumers as they are still trying to fix their support issues
This is where Pimaxes credibility goes out the window. Because look at this chart posted by Pimax well over a year ago. It shows Wifi6e Hardware and Software as Ready! Now its under evaluation? Some one telling porkie pies.
