Hello everyone !
I received my pimax 5K+ yesterday.
I’m running iRacing.
I have one big problem (except the low quality in straight line, lot of aliasing) very disturbing for me :
If i look straight ahead, it looks okay.
If i look anywhere else without moving my head, like below (where i have my steering wheel, lap time, gap with opponents) or if i look up (comments, mirror) it’s blurry.
Blurry enough to make it hard to read, so i have to move my head. Problematic when you are driving fast.
Is that normal ?
If i do an IPD test in front of my mirror, it seems i have a 65mm IPD. I set it up like this but it’s the same.
Any suggestion ?
I too have an IPD of 65mm and I used some velcro strips (one layer) to thicken the face pad/foam a bit which helped a lot on the distortions. I don’t notice it anymore…
you had the same problem ? it was blurry as soon as you don’t look straight ?
I feel i’m too close from the lenses. Sometime my eyelids even touched them.
I’ll try that !
I’m buying the deluxe audio strap and printing the adapter also.
I was quite disappointed yesterday with everything being blurry when i moved my eyes.
i didn’t see your answer sorry.
no i don’t have this fixed foveated rendering option.
i think my problem is IPD related but i still can’t figure the good setting, or if my measure fits inside the PIMAX range.
i’ll try the picture you talk about.
so far in iracing or even pimax home, it’s impossible for me to see something clear in both eyes if it’s in front of one eye. The other one will always see it blurry.
As i lower the IPD settings it gets better, but not clear. I am afraid that i maybe have a lower IPD than what the helmet offers.
Same problem for me, i have a ipd of 64, tryied realy every ipd setting but it seems that there are missing some more mm to get lenses closer for a realy good image. I got also a problem with the world scale, everything is bigger than it should be. Hope i will get soon response to my ticket.
