Hi everyone,
As I had problem with the Pimax 5K+ I ordered, I finally received my replacement HMD, and after checking that it was working ok went straight to test the eye-tracker.
So I installed it, plugging it on the top usb-c port of the HMD, cutting the confort kit as necessary, plugged it, and launched the calibration. And nothing… I mean, the Unity scene actually loads, I see two green dots for a second, and send the dots disappear.
I spent all day going through the forum, trying different things, and nothing works. I’m running Pitool 1.0.2.084 (with aSeeVR 1.0.0.10), but I have also tried installing aSeeVR 1.0.0.8 I have the same trouble. I’ve checked using the recommended AMCap software, but cannot get to find the options mentioned on this post. I do get a green screen when i select Droolon Pi1, with 320x480 resolution and 60Hz. My understanding is that it should be running at 120Hz, so I wonder if something is wrong with the eyetracker.
Also, I’ve checked through the log C:\7invensun\aSeeVR_UserSDK\runtime\aSeeVRServer.log, and get the following error (like the server does not manage to establish the socket connection to the eyetracker).
[2021-03-11 21:40:39.262]: sdk path: C:\7invensun\aSeeVR_UserSDK\runtime\devices\Pimax\config
[2021-03-11 21:40:39.263]: service addr: 127.0.0.1:5777
[2021-03-11 21:40:39.796]: sdk path: C:\7invensun\aSeeVR_UserSDK\runtime\devices\Pimax\config
[2021-03-11 21:40:39.813]: internal sdk init: 0
[2021-03-11 21:40:39.813]: internal sdk set image callback: 0
[2021-03-11 21:40:51.174]: internal sdk start camera: 0
[2021-03-11 21:40:51.174]: internal sdk start gaze callback_ex: 0
[2021-03-11 21:40:51.174]: tracking mode: [3]
[2021-03-11 21:40:51.174]: internal sdk start tracking: -3 -3
[2021-03-11 21:41:18.654]: 3 socket err: 0 0 2340
[2021-03-11 21:41:18.655]: breakdown: 1
Before logging a ticket, I was wondering whether anyone had any feedback, or idea about what I might be missing.
Cheers,
