my problem is that my right screen don’t works good.
FOV looks bad, orientation is a little too much on the left, and when i move my head around me this screen has image distortion !
Sorry I can’t tell you exactly which setting, I haven’t used the 5K+ in a while. My setting is for the Index, but my guess is that you have to use 1 if you have SPS on(this saves performance), and use 2 if it’s off. Depends on your graphics card too.
[OpenVR]
TwoStageAA=1 ; Repeat AA after the UI draws (note: consumes more vid mem)
AlignmentFix=1 ; 0=off, 1=simple (SPS), 2=simple (always), 3=advanced (SPS)
MirrorViewVerticalShiftPct=0 ; -30 to +30 percent - shifts the mirror image up/down (if clipped)
FullyWaitForSync=0 ; Improves timing/lag below refresh rate, but costs a little all of the time
PredictionMode=1 ; 0=off, 1=dynamic, 2=fixed
OpenVREnabled=1 ; Enable OpenVR Support
AutoSelect=0 ; Use OpenVR without prompting (note: Oculus has priority if enabled)
AutoCenter=0 ; Re-center the HMD pose when health/safety warning disappears
