Problem :
Image suttering/offbeat when i move the head. In Games, in Steam Vr home and in Pimax vr Home.
When i don’t move or move very slow the head no problem. When i move as normal the image don’t follow well, it’s like you see 2 images not align and shaking.
My situation :
The configuration had no problem with the prévious one.
old config
Asus z97a
asus rtx2080ti
32g ram DDR3
i7 4790k
ssd
New config
Asus Tuf z490 - plus
Asus 2080ti
i 10700k
16g ram DDR4
-ssd
What i’ve tried :
test pitools from 197, 249, 255, 2060, 261 etc.
Test previous firmwares
update all drivers for my motherboards etc.
plug the usb cable on different usb. One my motherboard and on my pcie usb card.
Enable disable smart smoothing/parallel projection etC.
Light houe/9 axis
144/120/90 hz all fov etc.
The only modifications i could have were on pitool versions. Some were just worse. I runngin atm pitool V1.0.1. 2060, fmw V2.1.255.264
Teigue thank you so much… I looked to Asus gpu tweak 2 and it was on low profile mode… I’ve turn this to full power and now it works well. Thanks to your idea to check Asus soft i’ve find the solution and i tell you a big THANK YOU !
Thanks @Thall@RaiN274 to otherq aswel who tried to help great community ^^
Yeah. After testing again by unistall and reinstall tweak tool i confirm we must deal with the soft.
For Asus users if you have same issue here is the solution : click on the gaming booster in asus tweak 2 and do the process. After that the image in vr will be smooth
Here is one last clean post to explain the solution after investigation.
The problem was Lightning service task on background. If you have same issue remove this from your computer.
What asus GPU tweak does when you chose option “boost the system” is improve visual, cut services system and memory fragmentation.
When it cuts system services it also cuts Lightning service, that is why that worked at this time. But to be sure to run with no pb later, just remove this service.
