(EDIT) Ok I was having the same issue.you.described. But some one earlier mentioned tha tthe in-game supersampling was set very high for a different headset.
Last time I played raw data was on my rift. And I think I had it set to 1.5
I went to the Raw data folder in my AppData folder and erased all of my old settings.
And now everything runs ok.
Changing shadow quality in-game causes a crash. but you start it again and its ok.
I still cannot get this game to work. Parallel projection enabled doesnât help. The game just flickers all over the place in front of me at crazy broken angles, duplicated everywhere. Thatâs the best way I can describe it I guess. Canât interact with anything.
Bummer, it runs fine for me but only after doing as others have mentioned⌠I had to take the steamVR SS to like 20% because the game settings were set so high i was getting like single digit FPS at best. After resetting settings and taking steamvr ss to 100% it works fine.
