Can anyone at @Pimax-Support please look into the latest/s PiTool version/s being a problem for vorpx 's users ?
Thanks!
Thanks!
Yeah this has been discussed. Originally Pimax was detected as a Vive. Pimax eventually had pimax headsets identify as 5k/8k etc⌠This caused problems for games that specifically look for Vive id.
So pimax put in a âVive Compatible modeâ to fix this. This kind of option will not be needed in future with games not looking for a specific brand.
Really on the reverse Ralf should just have a setting in Vorpx where you can set/force the headset brand.
After all many games let you choose Display & which sound device you want to use.
Ok. Thanks! I will let him know !
