So I was able to get extended mode working along side Oculus Software on 2 of my setups. (Refused to give up Revive).
System 1:
EVGA GTX 1080 (Drivers - 376.09)
Win 10 Enterprise x64 Build 14393.447
Pimax 4K Firmware 1.0.0.230
Piplay 1.1.88 (Beta International)
System 2:
EVGA GTX 960 SSC (Drivers - 375.63)
Win 10 Enterprise x64 Insider Build 14936
Chances are when extended mode refused to take after Oculus Software was installed, you’ve unplugged the USB/HDMI multiple times and even tried different ports?
Highly recommended to create a restore point before proceeeding any further & disconnecting from internet or blocking the Pimax software from accessing the net. (A random firmware update will possibly “brick” the Pimax 4K if USB/HDMI disconnection occurs).
The method:
Go to Device Manager/View and Select “Show hidden devices”
Scroll down to the “Monitors” Section (There should be more than a few “ghost” Generic PnP Monitors listed & possibly Rift DK2).
Right-click them & Uninstall all “non-active” Displays (ie, Displays that are not in use).
Now Activate Extend Mode in the Pimax Software. (It should now be possible to switch between Extend & Pimax Mode).
Note:
Switching Between Modes sometimes crashes Windows Explorer, if this happens, open Task Manager, Right-click Windows Explorer & select restart.
Use the OCPlugin to get back into Pimax Mode if Extend Mode does not work. (Simply run it & select Pimax mode/Restart Tab).
Unplugging/Replugging the Pimax 4K after selecting Restart Tab also helps.
