Pimax 4K with glasses
Hi guys
I am looking to swap my B1 for the 4K but i have a problem with blurr in the centre of the lenses and it sounds like it’s the same on the 4K.
What I would like to work out is, are my eyes faulty or the lenses.
If you guys that wear glasses use it without, do you have a blur patches right in the middle.
I don’t normally wear glasses but may be I need to for the Pimax.
I had a couple of friends try my hmd with their glasses on and they noticed the blur but worse than that their glasses steamed up straight away, how do you stop that happening.
Any help much appreciated
Hi, like we said in Forum, we had one batch of units occurred this issue of blurry center and sharp edges in the first half of last year, since they were assembled with wrong holders.
The current helmet you used belongs to later batches which should not have this issue. I’m pleased to deliver a pair of new lens with holders for you, but it may not help.
Normally Pimax helmet itself can support myopic users under 300 degree without wearing glasses to experience it, however users should wear their prescribed glasses to use it in other eyesight situation, e.g. myopic over 300 degree, presbyopia or astigmatism.
Hope other friends could give you a good advice :slight_smile:
I have just had a look at my last eye check and I see I have a prescription of +1.25 so I will get some glasses tomorrow and give it a try.
Hopefully that will sort out the blur.
Do you have any tips to stop glasses steaming.
4K is anti-misting by itself. for myopic glasses, my personal experience is to use anti-fog leans cleaners or vaseline.
Thanks I will give it a try.
Is the B1 model anti misting
yes, B1 is anti-misting as well
Spoony,
If you wear glasses for long sightedness have a look at the Pimax forum Myopia VS Presbyopia - you will find two methods of adapting the Pimax for this - 1 invasive and 1 non invasive.
Hi
I have tried glasses and it did make the centre blur better but it made the peripheral image more blurry.
I don’t know which is worse.
The problem now is the glasses misting.
I am exchanging this unit for the 4K so I would do the non invasive mod on the next one.
Cheers
