The virtual world is tilted a few degrees to the side and i dont know how to solve this. There is also a problem with the recenter and other control devices. I wanted to play DCS and start outside of the plane. Ist like sitting on the wing. When i press “Recenter”, nothing happens. I have to play with the camera controls in DCS to get me to the right positions.
Also my Joystick, Throttle, Rudders, Keyboard and Mouse are not working as they should. This only happens, when i start the Pimax 4k. For some reason they work for a second and i can press a button in the Cockpit and in the next second they dont work and i have no control. I have no idea why this happens. As i said, there are no problems, when i play without VR.
I`m using PiPlay Version 2.0.5.46
Anyone else had this problems and was able to solve them?
1st thing to mention the tilt on the horizontal has been a issue from the beginning but the latest piplay says it has new algorithm to help reduce it.
Open piplay and run the magnetic calibration. See if that helps.
Regarding the mouse/joystick etc not working… I get this if I have clicked outside of the game window on my monitor.
Lift you headset off and then move your windows mouse back into the game window and click again… What I usually do if set my monitor game window to 1920x1080 so less chance the mouse moves off the window when playing.
