I tried everything but vision doesn’t comes. Everything looks like fine.
Can you post you system specs.
If your using Amd gpu install previous driver. I had that problem grey screen with sound & desktop windiw showed head movement
Same problem here. The led doesn’t go blue or red anymore. I’ve tried everything.
If your running a vega gpu you need a special firmware for the headset.
This thread has the firmware
