Hi,
I just got my Pimax 4k and I’m really excited about getting to use it, but I’m having endless problems getting it to work properly.
I’ve installed PiPlay from a link I found on this forum since PiTool doesn’t seem to support the 4K. I also installed the oculus software as most of my games render for the Rift.
If I go into piplay and set the HMD to Video mode, I can watch 2D movies without any problems, but if I switch back to Pimax mode and try to run SteamVR or any of my games, the HMD does not display any images properly. If I look at my PC monitor, I can see the image and it is tracking properly, but all I get in the HMD is a blank screen that seems to flash in solid colours, based on what I should be seeing. So for example, if i’m supposed to be seeing an image of grass, the display might flash green and if I look up at the sky the display flashes blue. By holding my head still in some positions, i can get it to display the solid colour on the HMD constantly, but it ONLY displays these solid colours and not any kind of image.
It must be some kind of software setting that I’m just not getting right, but I have no idea where to look any more because I’ve tried everything I can think of.
Setup Info:
Windows 7
i5
16Gig RAM
NVidia 1050GTX ti
Currently running 2 monitors and Pimax from same Graphics card.
