Pimax 4k black screen
my pimax shows a blue led and a backlit screen but screen is black and does not show anything. I have tried re-installing piplay to older version and current version but does not work.
Going by Memory you need tot go to settings then where it shows device there should be a box for display in 1080p…you must check the box. Good luck
Can you post your system config?
Windows Ver
Cpu/ram
Gpu/driver version
Piplay version & first 3 serial numbers ie 100 or 102
Also just in case the headset will stay off until the sensor between top of the lenses is blocked.
This link may help.
http://community.openmr.ai/t/p4hlp-getting-started/5851?u=heliosurge
Also please try another USB port on your machine… Don’t use a USB hub
