@Sean.Huang @PimaxVR @deletedpimaxrep1
Now that we see that the 5K+ and the 8K make even the most expensive GPUs bleed, I have a suggestion.
For a 4K V2 Pimax should copy Varjo’s fixed foveated display concept.
Source two micro LCOS displays of 1280x800 for the foveated region, and use 1 panel from the 8K as the “context” display.
If you had an HMD with 110 degree FOV, native 4K, stean tracking, and a fixed foveated micro display in the center, your HMD would beat everything on the market, and what.is better is that you could run it on a 1070 or 1080.
