Hi i was using .35 for the first time. Since you said it was ok to use the normal PiTool now, I uninstalled Pitool and cleared all of the AppData, ProgramData, Program Files folders
and reinstalled fresh
my firmware is also 264
anyway launched PE and everything was beautiful.
I went into the settings for HL ALyx and changed the super sampling and I noticed everything flicker and suddenly get very aliased looking,
I figured … okay it tried to apply the setting right away. Which is weird because when setting profiles for games why would it apply right away. It should only apply it when the game runs.
anyway…
frame rate seemed to get a tiny bit choppier.
So i then went into the settings and i changed the refresh rate there.
Suddenly my framerate looked like it was getting 15 FPS
I had to turn off PE it was too choppy to continue.
PE should not in any way affect game performance, as it shuts down the same second any game or SteamVR starts. Maybe its a driver issue? You said its a new windows install, did you have the same problem on that install before you tested PE?
PE applies profiles to HMD manually and automatically (also upon game launch if preferred), but thats simply PiTool settings so it doesnt make any difference in performance if you make these settings manually in PiTool instead.
Since a few versions back, PE uses Forward Rendering and 4x MSAA, but thats only enabled by Unity and not in Nvidia settings or anything outside PE. So it should not affect performance.
Im sorry I dont know whats causing your performance drop, but I suspect there might be settings in NVidia panel, Windows, SteamVR or the game itself that you have forgotten to change since your new install.
Btw, turn off the screen saver in PiTool while playing. I have seen weird performance drops when having it enabled in the past. I only use it while coding in Unity and HMD is on all day long.
