Pavlov requires parallel projections, but isn’t it a unity game? What should we tell the dev so he can fix it?
I want to contact the pavlov dev and tell him to fix it so it doesn’t require parallel projections anymore. It’s a unity game so should be easy to fix right? What should we tell the dev? How can he fix it?
Or maybe @PimaxUSA or @Sean.Huang could contact them…?
His twitter: https://mobile.twitter.com/davevillz?lang=en
The new beta doesnt require parallel projections,and will be out soon!And its great!
where did you hear that?
Really? That would be great! Do you have a link to this?
yes i play the new beta.
But everybody can, if you go to your steam game and select Pavlov beta.
There arent many players yet on the new beta,but when its go live then you have again alot off people to play against!
Ooooh! I was hopping that was the new Pitools beta! :rofl:
It’s “only” the Pavlov Beta, ok. That’s good.
YES THE PAVLOV BETA…:rofl:
omg i thought you meant the pitools version isn’t gonna require PP… ARGHHHHHHHH
sorry,i did wish that too tho
Only the blood effects on the walls and floor is not right at the moment and needs parallel projection,i hope they fix that
Fixed,
the devs from the game Pavlov helped me…
In the menu select force no post proccesing,and now the beta runs great without any parallel projection and all is great!
