So, i noticed this the past couple of weeks.
but was unsure of what is causing it till now…
I even went back to Pitool V272 as a test and it still did this(was on V274).
So, i was playing After the fall and i noticed i was randomly being spun around then facing front again.
like a quick jolt… i did not know what was going on.
Today, i decided to play some Valheim VR, and noticed the same thing.
i had an idea to turn on parallel projection(PP)(noticed my FPS went from avg 54-62fps to 42-52 fps, and picture is softer, why i hate parallel projection).
anyways noticed the random jolt of being spun around then back again vanished when (PP) is on.
thought it must have been coincidence… turned it off and it happened again…
i notice it more if i manually try turning my body to the right in Real life…
Any help on this or if it’s a known issue???.
Pitool used: 1.0.1.274(tried down to .270)
Headset: Pimax 5K+
this is something new, and have not really noticed as i have been mainly playing VRchat.
(but i did not notice in boneworks or pavlov either)
not sure which pitool version this sneaked into…
Edit:
i CAN’T even use pitools lower than 272 to test…
i tried both 271 and 270, and my headset now remains in a yellow light mode and will not be detected.
if i use versions higher(272+) it loads… might be a firmware thing that no longer supports older ones…
Edit: i manage to get 270 tested, same issue.
if PP is off random jolting, if on fine…
