Is there away to get back overlays and menus in project cars? I migrated from osvr HDK2 to Pimax 4K because I wanted to get rid of screendoor effect. And I am wery pleased with that, but instead I lost menus and and HUD overlay inside the gogles. And the display is not clear.
I had a similar problem with Dirt Rally. For me, 1.1.92 displays everything correctly, because it has better compatibility with steamvr. What version are you using? Try 1.1.92.
Latest version I guess, I am new last week.
You was right, menus and overlay HUD is present in 1.1.92, but the overal quality and framerate was bad. So I instaled latest piplay again. Can live without HUD and menus.
I have the same issue with my R9 290.
Just go back with the old 16.12.2 drivers and it solved for me.
OK. I have Nvidia GTX1080. I am not a fan of going back to earlier driver. (Every new should be better than the old.)
1.1.92 is much much much way more better for 1080 then the new version of pimax.
1.1.92 allows you to get best possible picture today and includes all modern features like async reprojection.
Is there any way that Pimax support can have a look and let us know about this please? The menus display in the mirrored view on the monitor but not on the HMD, so the in cockpit menus are going missing HMD wise…
yes, it’s very difficult in game…
Support please !!
Thank you
Yeah, can we get some info on this? It happens on multiple games so a fix would be nice. I would use the new driver if you would only fix the Steam VR menus problem.
